Message Control Bypassing "Suppression" when Reloading Service Engine
I am running zenon 11 Built 101682 64-bit. We have a system with Message Control operating generally as desired with SMTP emails working properly. The issue is that when we reload the Service Engine to apply the updates via a standard "Reload" function,
Proposal: Implementing User Voting System
Hi, I propose implementing a user voting system for feature requests. This system will allow users to submit and vote on features, fostering community engagement and providing valuable insights for prioritizing development efforts. By empowering users
Multiple Functions on a Button
Hi! I wanted to know if there is a way to make buttons change its assigned function dynamically? For example: I got a text component and 3 functions that change the text on it, lets call them fun_1, fun_2 and fun_3; And a button that I want to trigger
Elements Gestures c#
Hi Support ! I use Element gestures (till now i only used "tab") So if i implement element gestures like this: example for test: IProject AP = null; public void Start(IProject context, IBehavior behavior) { context.ScreenCollection.ElementGesture += ScreenCollection_ElementGesture;
Add columns to CEL list
Hello, is it possible to add non-standard columns to the event list in Zenon? I need to manage additional text fields beyond those visible via filter. Let me explain further: I need to display the following columns: Time Received -> ok Identification
Start the process gateway in silent mode (option /hide).
Hello everybody, so far I have used the function "Start Program" to launch the process gateways, and I add the option "/hide" to the parameters to not to display the small window where the user can modify or shut down the gateway. The last versions of
Reporting Studio can't connect SQL server
Hi, I learn zenon report engine on zenon academy. (https://www.zenon-academy.com/content/course/231/lesson/436/content/2296) I have download the demo project and run service engine. In this step, run the Reporting Studio, and connect sql server. It's
Zenon 11 Silent Install -> .Net Hosting Bundle
Hallo, wenn ich das Zenon 11 Silent installieren lassen möchte, kommt diese Meldung. Im Download File von Copa-Data kam erst nur die Version .NET Hosting 6.0.7 mit und das Setup wollte dann mind. 6.0..11 Nun habe ich via Silent Batch die .NET Hosting
Zenon Report Engine Problem
Hi! I have a problem with Zenon Report Engine. I'm making Zenon Report Engine training. https://www.zenon-academy.com/content/course/231/lesson/436/content/2297 In chapter Reporting Studio & First steps - Metadata Synchronizer, I'm not able to choose
instalation zenon versão 11
My Automatic Line coloring Partially Works
Hi, I just finished the Zenon Basics and Moving forward with Energy Version. I am following the instructor step by step and doing it myself at the same time. I succesfully added my disconnectors, circuit breakers and draw it. When AC Source is off, all
Archiv - Datenimport
Hallo zusammen, ist es irgendwie möglich, eine CSV-Datei, so wie ich sie aus einem Archiv exportiert habe, wieder in ein Archiv zu importieren um dies in einem erweiterten Trend darzustellen? Es handelt sich dabei um 1000 Werte in einer txt-Datei, wie
Combined Element Configuration and Test
I recently discovered this Combined Element and it has great potential for what I want to do. I am going to use it a lot but it has limitations as to how efficient and fast I can configure the element. I am attaching a screenshot if incase it might help
Symbol Group - Folder
Hi, In symbols library the option new symbol group is greyed out. Is there any way to create a new folder? Currently, we have to much symbols in project and it does not looks good. BR, Jakub Gritner
Variable mapping via UANodeSet
Has anyone used OPC mapping to a UANodeSet file with SiOME CUSTOM_NODESET_FILE= myFile.xml CUSTOM_NODESET_MAPPING_TYPE = 2 I have no problems with the variable itself, it is an AnalogItemType and works just fine. But the EURange and EngineeringUnits propertys
Popup window
Hi I'm using Zenon 6.22 SP1 and i want to make a popup window when an event occurs. With two YES / NO buttons to activate a boolean variable of a plc. As I can do thanks greetings :) This is a migrated post! Originally posted on 08.08.2014 by user cibertoni.
Download Zenon 6.22 SP1 Build 24 after changing the project.
How to download Zenon 6.22 SP1 Build 24 after changing the project. I've created some "Alocations" and I need to offload them to HMI. Does anyone have the procedure?
Does “Interop.zenOn.dll” is compatible with multiple versions of Zenon runtime ( 8 and above ) ?
Does the “Interop.zenOn.dll” is compatible with multiple versions of Zenon runtime ( 8 and above ) ?
regarding the license activation
hi sir, when i try to activate the zenon 10 license ,a pop up message is come showing that "several dongles were found" how to remove this error. dongles id and error message is attached below thankyou don m anto
IEC870 variable
Good day, I have a variable that arrives in ICCP protocol, from origin they gave me the following data: iccp datatype - Analog plus quality plus timestamp extended / datakey: 1 / scope: system / Slope: 1. Therefore I configured with driver iec870, but
ARCHIVE START ,STOP, PAUSE, RESUME
hi everyone , i have to create a batch report which is recorded according LOT variable but problem is the process is different example : started batch ABC01 (Archive Recording started) then run for 2 hours and it need to hold for 5 hours for chemical
Alarm shelving
Hello, How can create alarm shelving with activation and deactivation in runtime without depending on the time setting (Shelving duration). Kindly help me to find the solution.
How to Connect to Zenon runtime present on remote PC using C# .NET?
PC1 has Zenon runtime installed ,PC2 has application written in C# .NET . Application wants to connect to Zenon runtime SCADA present on remote system and fetch Project, variables . How programatically(C#.NET) I can connect to zenon runtime on remote
API Interfacing in Zenon
Dear All, I am using Zenon 7.00. We are trying to interface the Zenon variable with VBDotNet. How can we get the API (.dll file) file for interfacing with zenon and VBDotNet....? Your quick reply is very helpful for us to work on this task... Best Regards,
WPF Binding elements
Hi! Have anyone tried using Telerik libraries to create charts? Were you using ObsevableCollection to create series of variables? I need support in implementing some solution using the collections. Thanks in advance. Best regards, Grzegorz Kaczmarczyk
WPF DependencyProperty & structural variable behavior
Hi all, I have two types of dependency properties, with different naming conventions in registered "name" argument, what is equal to zenon variable name: 1) PlainVariableName 2) Plain.Structural.Variable.Name.With.Some.Amount.Of.Levels.Or.Plain.Variable.With.Dots.In.Name
extended trend crashing
hi i am trying to plot an extended trend (xy graph) using RDA sampling. i have 3 variables, with 300 000 samples each over a 50 minute period. one of them are for the x axis. but zenon keeps freezing. i can squeeze out about 100 000 samples per variable
Extended Trend - Exclude values with INVALID status
Hi, How can values with INVALID status be excluded from showing in extended trend. All trends with automatic scaling become useless due to INVALID status which has value 0(Screenshot below) For example for screen type "AML" there is a tab menu "Status"
IEC 101 protocol with simulator
Hi, I configured IED variables in IEC 101 protocol and used IEC60870-5-101 sever simulator to test the IED open and close using command processing. When , i try to close/open the Circuit breaker, SBO rejection is occurred. The observation in diagnostic
Where can I find ZenOn PC Runtime V5.5 SP7?
I only need the installer of ZenOn PC Runtime Version 5.50 SP7, to install in another PC because the PC where was installed it, damaged, and I need to migrate the proyect to another PC in order tu Run the machine again. I don't need to edit, I only need
Add comments to specific LOT
I use LOT archiving in Historian, start of archive by function, and the time/lot filter to search and display a specific LOT. I use the id of the product in the machine as lot name, so it works quite ok. Sometimes there is a need to add a comment the
ZENON 12 installation failed on Windows 11
Good day, I am failing to install ZENON 12 setup on my Windows 11 PC (Windows 11 Home, 64-bit operating system, x64-based processor). Kindly find attached the log file with the error message. Would you kindly assist in troubleshooting this issue? Kind
Setup Failed
I'm always fail to install the zenon complete setup. I'm trying zenon 11 and 12 but all of them is always failed to install. Here by I'm attaching the log file and the failed package to install. Do you have any solutions?
IEC 104 protocol with SBO rejected
I configured Bay in SCADA and communicated IED with IEC 104 protocol. While doing CB close and open, i used two step verification with command processing. I also enabled the "select before operate" checkbox in the "Control" variable properties.. With
Import Variables from Bacnet EDE files
Hi, is there any way to cleanly import variables into the BacnetNG driver using EDE CSV files that were exported from a PLC using a Bacnet browser? It seems like Zenon expects a certain structure for CSV variable import to work, is there documentation
How to set Entire Vba Project to variable
Hi Dear support! I am trying write more complicated function but i have a problem with find VBA project, for example (easy example to show problem) what i should set in Set vbProj = ? for example in Excel i will set = ThisWorkbook.VBProject Sub LookingForStringInEntire_VBA_project()
Create Variables Counter
Hi all, Could anyone help me? I want to make a function, addin, or logic (IEC 61131-3) to count the number of variables based on their identification in the engineering studio, and the total counted number appears in the service engine as dynamic te
Translate Variable value coming from C# Addin
Hi, I am developping an IProjectServiceExtension Addin. Inside my code, i push values to variables this way : ThisContext.VariableCollection.GetItemById(VarNameToId.FirstOrDefault(VarD => VarD.Key == "VariableName").Value)?.SetValue(0, "Text Value");
Not able to run engineering studio 10 32 bit in demo mode
hi, due to some error I reinstalled zenon 10 after my demo mode was finished and engineering studio was running only for 10 minutes. now after i re-installed the software, my license manager is not working and no demo option (even for 10 minutes ) is
The Installation Failed Zenon Version 11. The Following errors were detected while checking the SQL Server 2019 setup Configuration
Any Solution ?
Next Page
