Can't read variable from ZENON in API C#
I have tried all Syntax I can still can't Read an Integer Value from Variable in Zenon Please if you know how to Read and Store the Value in C# VAR let me know...
ZenDbSrv Issuse
Hi, I have an issue in Opening the Workspace/Eidtor. While opening the editor, Error is Showing as ZenDBSer.exe not running. When Internet is disconnected from PC, then its working fine. Zenon Version used : Zenon Energy Edition 8.00 I tried doing standard
two single binary input at doble point binary (usint)
I have two digital values which I want to convert into a double value, but preserving the time and quality stamp of the original points, what is the simplest way to do it?
Command Processing
I do not understand why ı get 2 as an value in the Command Processing. Can anyone help me. We are currently testing our scada but we could not observe any changes when we press open or close buttons in command screen Regards Berk
ICCP gateway
I am doing tests with two zenon 11, one collects data from a device in dnp3 and sends it by iccp to another zenon 11, but the second zenon does not correctly show me the time stamp of origin, instead the zenon that is connected to the device dnp3 if the
Why Zenon 7.20 full setup is not available on official download page other version are available but why 7.20 is not ?
Why Zenon 7.20 full setup is not available on official download page other version are available but why 7.20 is not ? i have used it in my earlier projects.
Setting up Start Type property in add-in source to Automatic
How to set Start Type property in add-in source?
I have a project which resolution is 640x480 i want to change to 1024x768
I have a project which resolution is 640x480 i want to change to 1024x768 Which tool should i use Thanks
Email a generated report daily
Hi support, I have a Zenon report in the report viewer screen built that users of the system have to get onto the zenon system to generate every day at the same time. Is there a way to generate the PDF version of the report and email it to the users daily
PLC driver communication error
Hi, I am currently using 3S V3 Driver. Whenever I use gateway v2.3 1200, TCP L2 Route the variables do not communicate at scada level and if I use Arti instead of gateway, communication breaks in between and I get the log RPC Error.
Web Client login using Active Directory
I have configured Active Directory for zenon 8.1. All the users login work fine with RT however with web client I get the diagnosis viewer log as couldn't connect to Activate directory server.
How to generate a report from evacuated arx file?
Hi! I already have a report viewer screen that shows a report from the archives that are nor evacuated yet. But I'm struggling to generate a report from archives that where already evacuated, so my question is how can I manage to do so?
Report Viewer - How do I get Report Viewer to display only the last value for a variable
Hi! I'm trying to make a Report Viewer Screen to show only the last value for a variable, I have already configured archive and report, but if I make the report only show 1 entry it always shows the oldest value. How can I make that entry to be the last
Locked on database Server
Hi Support. I have a problem creating a backup of a Project. It Gives me a Error Msg as " Project Instance 'xxxx' is locked. you can unlock it from zenDB Admin." Can you tell me how can I unlock it? This is a migrated post! Originally posted on 19.08.2020
Problem with the ALC module (Automatic Line Coloring)
Saludos, ¿alguien sabe por qué se bloquea la opción de establecer coloración automática de líneas (ALC) cuando establezco un estilo para las líneas que representan barras o conectores en un diagrama unifilar? Este problema no ocurre si edito manualmente
Zenon update
Hi everyone! Is it possible to upgrade Zenon V6.5 to the current version? What are the steps?
Write all current values from Zenon to PLC
Hi, I have a siemens S7-400 CPU, Zenon and Zenon IEC61850 client driver. When i loose connection to my S7-400 PLC i am setting some alarms. when the connection is back i need to write all the current IEC16850 values to the PLC again. how can i force write
Error when starting the drivers for project 0x8001011f
Hi, I am geting an error 0x8001011f when starting runtime. I get the same error if I want to open the driver. And the same error if I create new workspace with new project but for internal drivers. The whole error Error when starting the drivers for project
Automation Script Logic Studio
I want to create an Automation Script but it appears to me that I don't have that option available. How can I get the option available to me? I've attached picture of how the Help looks and then my logic studio.
Report-Viewer doesnt create Files
Hi, when I will load a new File of the Report-Viewer, the ReportBuilder open with failure message "Failed to open report 'Report 0.rdl'". At the details is written: Could not find file 'C:\ProgramData\COPA-DATA\SQL2017\e9bda79c-7da0-4ae3-ae21-a7622b0b08d6\FILES\zenon\custom\rdlc\Report
Migration Sicam230 to Zenon - Picture Alarming button
Dear Support Team, We have a big, multihierarhical project, which we have to migrate from Sicam230 v720 to Zenon v12. We have >1500 images. Totaly around 40.000 Variables. The picture alarming in Sicam230 was done with 3 different alarm classes (Alarm,
Blockarray in erweitertem Trend
Hallo zusammen, ich habe eine Kurve in einem erweiterten Trend aus einem Blockarray als Datenquelle. Diese Kurve hat 1000 Werte, sodass ich bei der Skaleneinstellung für die x-Achse 0 bis 999 angegeben habe. Ist es irgendwie möglich diese Skala, also
send telegram with 6byte data using modrtu32
Dear, Can somebody help me with the following. I want to send (driver MODRTU32) a modbus telegram(0E 10 18 D6 00 03 06 08 F7 00 00 00 01 5D C4) to a comap controller. The telegram must command a reset in this controller. I have made a recipe that puts
Message Control Bypassing "Suppression" when Reloading Service Engine
I am running zenon 11 Built 101682 64-bit. We have a system with Message Control operating generally as desired with SMTP emails working properly. The issue is that when we reload the Service Engine to apply the updates via a standard "Reload" function,
User Information Invalid?
Hey all, I'm doing some testing in preparation for upgrading from Zenon Supervisor 6.22 to 7.50 64bit. After gettting it installed, creating all of the runtime files and correcting some VBA scripting for 64bit compatibility, I started Zenon runtime and
Proposal: Implementing User Voting System
Hi, I propose implementing a user voting system for feature requests. This system will allow users to submit and vote on features, fostering community engagement and providing valuable insights for prioritizing development efforts. By empowering users
Multiple Functions on a Button
Hi! I wanted to know if there is a way to make buttons change its assigned function dynamically? For example: I got a text component and 3 functions that change the text on it, lets call them fun_1, fun_2 and fun_3; And a button that I want to trigger
Elements Gestures c#
Hi Support ! I use Element gestures (till now i only used "tab") So if i implement element gestures like this: example for test: IProject AP = null; public void Start(IProject context, IBehavior behavior) { context.ScreenCollection.ElementGesture += ScreenCollection_ElementGesture;
Add columns to CEL list
Hello, is it possible to add non-standard columns to the event list in Zenon? I need to manage additional text fields beyond those visible via filter. Let me explain further: I need to display the following columns: Time Received -> ok Identification
Start the process gateway in silent mode (option /hide).
Hello everybody, so far I have used the function "Start Program" to launch the process gateways, and I add the option "/hide" to the parameters to not to display the small window where the user can modify or shut down the gateway. The last versions of
Reporting Studio can't connect SQL server
Hi, I learn zenon report engine on zenon academy. (https://www.zenon-academy.com/content/course/231/lesson/436/content/2296) I have download the demo project and run service engine. In this step, run the Reporting Studio, and connect sql server. It's
Zenon 11 Silent Install -> .Net Hosting Bundle
Hallo, wenn ich das Zenon 11 Silent installieren lassen möchte, kommt diese Meldung. Im Download File von Copa-Data kam erst nur die Version .NET Hosting 6.0.7 mit und das Setup wollte dann mind. 6.0..11 Nun habe ich via Silent Batch die .NET Hosting
Zenon Report Engine Problem
Hi! I have a problem with Zenon Report Engine. I'm making Zenon Report Engine training. https://www.zenon-academy.com/content/course/231/lesson/436/content/2297 In chapter Reporting Studio & First steps - Metadata Synchronizer, I'm not able to choose
instalation zenon versão 11
My Automatic Line coloring Partially Works
Hi, I just finished the Zenon Basics and Moving forward with Energy Version. I am following the instructor step by step and doing it myself at the same time. I succesfully added my disconnectors, circuit breakers and draw it. When AC Source is off, all
Combined Element Configuration and Test
I recently discovered this Combined Element and it has great potential for what I want to do. I am going to use it a lot but it has limitations as to how efficient and fast I can configure the element. I am attaching a screenshot if incase it might help
Symbol Group - Folder
Hi, In symbols library the option new symbol group is greyed out. Is there any way to create a new folder? Currently, we have to much symbols in project and it does not looks good. BR, Jakub Gritner
Variable mapping via UANodeSet
Has anyone used OPC mapping to a UANodeSet file with SiOME CUSTOM_NODESET_FILE= myFile.xml CUSTOM_NODESET_MAPPING_TYPE = 2 I have no problems with the variable itself, it is an AnalogItemType and works just fine. But the EURange and EngineeringUnits propertys
Popup window
Hi I'm using Zenon 6.22 SP1 and i want to make a popup window when an event occurs. With two YES / NO buttons to activate a boolean variable of a plc. As I can do thanks greetings :) This is a migrated post! Originally posted on 08.08.2014 by user cibertoni.
Download Zenon 6.22 SP1 Build 24 after changing the project.
How to download Zenon 6.22 SP1 Build 24 after changing the project. I've created some "Alocations" and I need to offload them to HMI. Does anyone have the procedure?
Next Page
