Facing SQL Server Installation Issue while V12 Reinstallation
I am facing sql server installation issue while reinstalling zenon v12. Recently I had uninstalled v11 and v12 versions (they were taking a lot of space) and thay were working fine. I uninstalled those versions using total uninstall software as recommended
Access to project settings > file storage field "Online help"
Hello, in Zenon 10 the SCADA Addin Framework allows reading and writing into the "File storage" window that exists under each project's properties > General in the "Name/Folder" section. Almost all the folder fields are writeable in C# code by this syntax:
how to add CEL data on a Report?
Hi! I have a report that shows the variables from zenon application, but i want to also add data from CEL (like eSignatures). I already have a Historian Archive that records the data for variables; how could I add CEL data to it in order to be able to
How to increase String lenght?
Hi! I'm trying to make a dynamic text field that writes into a STRING variable, but I'm not able to write more than 5 characters, how can I increase the allowed size ? I am using this type:
UDFB input must be connected to a variable.
Hello In zenon logic i want to create Udfb using Vsigettime function block when I compiled the udfb program I get an error :VSIGETTIME input must be connected to a variable even if that i create the input variable and I connect it to the function block.
Service Engine Closes whenever I open the Report Viewer Screen
Whenever I open the Report Viewer Screen, screen opens and after loading for few seconds it closes the Service Engine. I tried with Archive data, Online data and CEL separately. but it is not working. I am unable to identify the problem.
How can ı add the audio for alarm list
Hi , I want to add some setting in my alarm list. I want to add the sound when alarm occurs and sound is stopped when user press the acknowledge button. İs there any way to do this. Thank you Regards
Zenon 14: .NET 8.0 ?
Hi, Release notes for Zenon 14 states the following: https://onlinehelp.copadata.com/Content.html?product=supervisor&version=1400&lang=en&id=F6E2F1BE7BF518C6D04148A6BD5011E1B0194946849DB3E37A5D2411C6F21377 But I can't find more than that about it. Template
Data-Base on Zenon
I need for my project to create a Data-Base on Zenon and then Read and Write on this Data-Base with The ADD-IN what the steps to do to make the data base and how to access it with the add-in
zenononlinehelp
I am unable to launch zenonhelp.
Service Node Configuration Tool
Por favor, ¿alguien podría decirme qué causa este error? Error Hubo un error al recuperar el paquete de https://localhost:9450/: El controlador del concentrador respondió con el código InternalServerError y el motivo Error interno del servidor, cuando
two single binary input at doble point binary (usint)
I have two digital values which I want to convert into a double value, but preserving the time and quality stamp of the original points, what is the simplest way to do it?
Zenon show all value changes - CEL
Hi, I want to use Zenon Chronological Event List or something like it to show all value changes. We are doing signal testing in the office. Is there a way to get a list in Zenon that shows all recent value changes and events, i also want to see the current
Command Processing
I do not understand why ı get 2 as an value in the Command Processing. Can anyone help me. We are currently testing our scada but we could not observe any changes when we press open or close buttons in command screen Regards Berk
Checkbox or Radial elements?
Hi, I'm trying to implement a way to select an option between 3 posiblities, but only one of those 3. I know i can use a combo-box but I want to know if there is a posible way to make somethin like a Checkbox or Radial.
ZenDbSrv Issuse
Hi, I have an issue in Opening the Workspace/Eidtor. While opening the editor, Error is Showing as ZenDBSer.exe not running. When Internet is disconnected from PC, then its working fine. Zenon Version used : Zenon Energy Edition 8.00 I tried doing standard
send telegram with 6byte data using modrtu32
Dear, Can somebody help me with the following. I want to send (driver MODRTU32) a modbus telegram(0E 10 18 D6 00 03 06 08 F7 00 00 00 01 5D C4) to a comap controller. The telegram must command a reset in this controller. I have made a recipe that puts
.dmp files fill clients memory on computer
Hello All, Our client has complained to us that .dmp files accumulate after turning off the Smart Client application. These files can sometimes take up to 100MB. Client have erased bunch of them, total 10GB. Is there any way to stop generate .dmp files
Can't read variable from ZENON in API C#
I have tried all Syntax I can still can't Read an Integer Value from Variable in Zenon Please if you know how to Read and Store the Value in C# VAR let me know...
ICCP gateway
I am doing tests with two zenon 11, one collects data from a device in dnp3 and sends it by iccp to another zenon 11, but the second zenon does not correctly show me the time stamp of origin, instead the zenon that is connected to the device dnp3 if the
Why Zenon 7.20 full setup is not available on official download page other version are available but why 7.20 is not ?
Why Zenon 7.20 full setup is not available on official download page other version are available but why 7.20 is not ? i have used it in my earlier projects.
Setting up Start Type property in add-in source to Automatic
How to set Start Type property in add-in source?
I have a project which resolution is 640x480 i want to change to 1024x768
I have a project which resolution is 640x480 i want to change to 1024x768 Which tool should i use Thanks
Email a generated report daily
Hi support, I have a Zenon report in the report viewer screen built that users of the system have to get onto the zenon system to generate every day at the same time. Is there a way to generate the PDF version of the report and email it to the users daily
PLC driver communication error
Hi, I am currently using 3S V3 Driver. Whenever I use gateway v2.3 1200, TCP L2 Route the variables do not communicate at scada level and if I use Arti instead of gateway, communication breaks in between and I get the log RPC Error.
Web Client login using Active Directory
I have configured Active Directory for zenon 8.1. All the users login work fine with RT however with web client I get the diagnosis viewer log as couldn't connect to Activate directory server.
How to generate a report from evacuated arx file?
Hi! I already have a report viewer screen that shows a report from the archives that are nor evacuated yet. But I'm struggling to generate a report from archives that where already evacuated, so my question is how can I manage to do so?
Report Viewer - How do I get Report Viewer to display only the last value for a variable
Hi! I'm trying to make a Report Viewer Screen to show only the last value for a variable, I have already configured archive and report, but if I make the report only show 1 entry it always shows the oldest value. How can I make that entry to be the last
Locked on database Server
Hi Support. I have a problem creating a backup of a Project. It Gives me a Error Msg as " Project Instance 'xxxx' is locked. you can unlock it from zenDB Admin." Can you tell me how can I unlock it? This is a migrated post! Originally posted on 19.08.2020
Problem with the ALC module (Automatic Line Coloring)
Saludos, ¿alguien sabe por qué se bloquea la opción de establecer coloración automática de líneas (ALC) cuando establezco un estilo para las líneas que representan barras o conectores en un diagrama unifilar? Este problema no ocurre si edito manualmente
Zenon update
Hi everyone! Is it possible to upgrade Zenon V6.5 to the current version? What are the steps?
Write all current values from Zenon to PLC
Hi, I have a siemens S7-400 CPU, Zenon and Zenon IEC61850 client driver. When i loose connection to my S7-400 PLC i am setting some alarms. when the connection is back i need to write all the current IEC16850 values to the PLC again. how can i force write
Error when starting the drivers for project 0x8001011f
Hi, I am geting an error 0x8001011f when starting runtime. I get the same error if I want to open the driver. And the same error if I create new workspace with new project but for internal drivers. The whole error Error when starting the drivers for project
Automation Script Logic Studio
I want to create an Automation Script but it appears to me that I don't have that option available. How can I get the option available to me? I've attached picture of how the Help looks and then my logic studio.
Report-Viewer doesnt create Files
Hi, when I will load a new File of the Report-Viewer, the ReportBuilder open with failure message "Failed to open report 'Report 0.rdl'". At the details is written: Could not find file 'C:\ProgramData\COPA-DATA\SQL2017\e9bda79c-7da0-4ae3-ae21-a7622b0b08d6\FILES\zenon\custom\rdlc\Report
Migration Sicam230 to Zenon - Picture Alarming button
Dear Support Team, We have a big, multihierarhical project, which we have to migrate from Sicam230 v720 to Zenon v12. We have >1500 images. Totaly around 40.000 Variables. The picture alarming in Sicam230 was done with 3 different alarm classes (Alarm,
Blockarray in erweitertem Trend
Hallo zusammen, ich habe eine Kurve in einem erweiterten Trend aus einem Blockarray als Datenquelle. Diese Kurve hat 1000 Werte, sodass ich bei der Skaleneinstellung für die x-Achse 0 bis 999 angegeben habe. Ist es irgendwie möglich diese Skala, also
Message Control Bypassing "Suppression" when Reloading Service Engine
I am running zenon 11 Built 101682 64-bit. We have a system with Message Control operating generally as desired with SMTP emails working properly. The issue is that when we reload the Service Engine to apply the updates via a standard "Reload" function,
User Information Invalid?
Hey all, I'm doing some testing in preparation for upgrading from Zenon Supervisor 6.22 to 7.50 64bit. After gettting it installed, creating all of the runtime files and correcting some VBA scripting for 64bit compatibility, I started Zenon runtime and
Proposal: Implementing User Voting System
Hi, I propose implementing a user voting system for feature requests. This system will allow users to submit and vote on features, fostering community engagement and providing valuable insights for prioritizing development efforts. By empowering users
Next Page
